Y2K MBZ C23OK W202
I AM LOOKING AT PURCHASING A 98 C43 EXHAUST AND WANTED TO KNOW IF THE DOWNPIPE IS THE SAME DIAMETER AS A 2000 C230 KOMPRESSOR. GIVEN THAT THE C43 IS BASICALLY TWICE THE SIZE, WOULD IT BE AN EASY SWAP FROM STOCK...GURUS YOUR INPUT PLZ... MUCH APPRECIATED.
1994 C280
Dont know if it will fit or not, but Im pretty sure it will sound stupid as there wont be enough volume passing through the muffler to sound nice. I reckon it will sound quite raspy. Maybe try getting a c36 muffler instead
Y2K MBZ C23OK W202
more specific
its just the muffler... do you believe it will still be raspy??? im not concerned about hp gains or sound... only looks... thanks
1994 C280
I sure do think it will sound raspy. A 2.3L cannot push the same volume of air that a 4.3L V8 would. Bear in mind, AMG would not have used an overly restrictive muffler on the C43 to start with. Why dont you try some other QUALITY aftermarket mufflers?
1994 C280
I really think a C36 exhaust is the way to go, or, something by Remus as they are fairly quite, but definitely smoother and deeper than stock.
2000 C230 Kompressor Special Edition
I would try to use a custom-designed Mercedes-Benz exhaust specially tuned for the C230 Kompressor.
I wonder where I might find one?
