300sl 1987
Hi,
I'd like to add this feature to my car but a few questions arise:
-On a w107 you only had the center vent temp option or was it also available as a digital display embedded in the cluster?
-Will a w124 digital one be compatible?
Mainly because a w124 one would be easier to find than the original center vent thingy...
Thanks in advance!
The cluster on my 107 has a blank filler piece of foam where the 126 temp display goes. On the 126 the sensor wire is attached to the body under the front near the foglights. It would be an easy retrofit.
Those idiot lights are on the right side in that empty area on mine.Maybe there's room there.
