Dear all,
I own a 1997 R129 since about a year and the paint has seen better days.
Since COVID came along I had time to replace the soft top hydraulic cylinders, some interior parts, tires (not myself), Oil (not myself).
Now I would like to learn & improve the paintwork.
I live in a Condo and Electricity is not near, therefore I would like to try my luck with a Ryobi P430G battery powered tool. Understandably it is probably too weak but I feel it is worth an attempt.
Anybody uses the Ryobi ?
Any suggestions how to convert it to take "regular" 6" pads ?
Besides, I would be grateful to learn about foam vs microfiber pads.
I wouldn't work with too aggressive compound, the car doesn't need to be perfect and as mentioned it is partially to learn, partially to use the spare time
THX
'87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 115,000+ mi
For the pad issue, you may want to consider Adam's 15mm cordless swirl killer, and the two-step kit (includes compound and finishing polish, plus brush for pad cleaning every panel or half panel (hood, roof, etc, clay bar, and recharging station). I think it will serve your needs just right, vs the Ryobi and it's size/pad limitation. The backing plate determines what size pads you can use, and the Ryobi unit may just get in the way if it even allows you to use the 5-6" backing plate.
