Am I the dumbest DIYer on this forum
It's almost 3 years ago. I changed the transmission fluid on my ML430. I drained the oil in the transfer case as well. As I could not find the refill plug, I thought the transfer case might get the oil from transmission directly. In other words, I did not refill oil to the transfer case.
While I was browsing the forum recently, I realized that the transfer case has been running without lubrication for 3 years. I couldn't concentrate on my work. I took off early and bought two bottles of ATF and filled it to the transfer case right away. Two days later, I changed the oil again to clean up the transfer case. What a relief when I saw the drained oil. It's a little dark all right. But, that's it. I don't think there is much permanent damage.
It is hard to find the refill plug. It's on the other side of the drain plug and behand some extroded part of the transfer case.
Here is the photo of the drained oil.
Any newbies care to share your interesting stories?
