I asked the always first gear option from Germany...
Here the is the answer from Germany - they do not prefer the "always first gear "- option. I will add "Kick down" or "Gear lever B short cut sw" parallel the mirror joystick "down" function. That will be enough for me.
"Hallo Yka,
I do know that all old MB automatic 4-gear-gearboxes always start in gear Nr2.
This is the normal gear nr 1!!!
What you have in these boxes and what is called gear nr 1 is an extra gear for special purposes. Should have been called gear Nr 0 !!!
The later gearboxes only have three gears. (2-3-4 !!! compared with the old ones.)
For example W 116 6-cylinders have 4-gear-automatic-gearboxes and the 8-cylinders have 3-gear-gearboxes, which has to do with sufficient output torque.
As you have a Drehmomentwandler (Hydrodynamic torque converter ?) you do need a first gear only when going uphill with a heavy camping trailer.
-" Whereby, the output torque can be up to 2,5 times higher than the initial torque, one reason why vehicles with an automatic transmission and torque converter often have one gear less in the subsequent planetary gearbox."
http://www.kfz-tech.de/Engl/Drehmomentwandler.htm
-So what is written on the page you sent: "First gear start - allows your car to work the way its designers intended." is bullshit !!!!!!!!!!!!!!!!!!!!!!!!!!
-MB engineers wanted the car to drive comfortable without switching unnecessary around between gears. Every single switching action is unnecessary high wear of the friction parts and speeding burns these parts.
"Particularly when pulling off, the work of the torque converter is often associated with a great deal of heat-development."
Who wanted to drive around "sporty" ordered another car with manual 5-gear-gearbox.
-I have never seen or heard of a thing like that before.
-And if I see one, I will destroy it ;-)))))))
-KR
Hans"
