How are the trim pieces held in place?
I would like to remove the bottom trim piece and know that in order to do so you use wedges and start from the center and work toward the sides. What I want to know is what holds these in place. I just want to know what I am in for when I go to reinstall it.
Are they glued in place? And if so, what sort of glue is used?
The left cowl vent has a rise on it in the left corner closest to the A-pillar and I believe that the trim is what holds that down and into place. If that's the case I would have to assume that at some point the trim was remove and not replaced properly. This has been bugging me for quite some time and since I have to have the hood repaired and painted this might be a good time to do it. (don't leave tools sitting at high points in your engine bay and then close your hood, it can be expensive. For that matter it's probably not a good idea to leave tools in that area at all.
Loren
Loren
