I've always had my stock Becker radio in the car. I used a cassette adapter to listen to the ipod, but I always got a horrible alternator whine/buzz in the speakers when I used it. I just assumed it had something to do with the radio being old, or a bad ground or something.
I recently upgraded to a Kenwood KMM BT318u. Weak output, comparable to the becker, but lots of features I wanted (including the omission of a CD player), and RCA outputs for sub, front and rear, because the next step was to buy a nice 4 channel amp to power the rest of the system I've been planning.
Until this... I have the amp I plan to use for the sub already installed in the car. I'm noticing the SAME alternator hum/noise that the becker was producing, coming from the sub amp (but NOT from the speaker outs direct from the receiver) It's not terribly noticeable, but I expect I'm going to have the same issue with the 4 channel amp, which will make the sound EXTREMELY apparent.
All of my grounds are good. The level of the noise does not attenuate when components/wires are moved around. I'm very close to getting a new alternator to see if this will solve the problem, but I'd obviously rather not if there is a solution I'm overlooking..
Also, I'm sure this goes without saying, but the noise is only present when the engine is running.
