AMG E55
01 E55
I'm getting a new noise (RPM relative) that's kind-of a cross between a buzz and a low freq whine......seems to be coming from engine front....possibly the poly-v or the alternator.
It can be heard at idle and with throttle it gets a tad louder and slightly higher pitched.
Sound familiar to anyone?.......or has experienced cost of either poly belt or alternator replacement?
TIA..........GreggT
A slight whine like noise is normal, my 55 has it, my old 93 400e had it, and my wifes old 98 C280 all had a similar whine like noise. I don't know where the sound comes from, maybe the water pump but in all three of my cases it is no big deal.
If yours is a new sound that just popped up then maybe you do have water pump or alternator bearing problems, get it checked out and let us know what they tell you.
AMG E55
OK........it's the alternator.
Prognosis is she's about to fail.
Part cost from dealer is over $700.....plus install.
Did I say that she went off warranty month before last? [:(]
You probably can find a decent local MB mechanic that is less then the dealer, an alternator replacement is not all that tough to do.
A Bosch rebuilt alternator for our cars is about $300 off the net... so considering that a mechanic needs to make a living you should be able to get a rebuilt one installed parts and labor for about 5 to 6 hundred.
