2003 230 Kompressor, 1970 280SL, 1991 300SL, 1970 SEL Limo
I'm looking for a direct alternator conversion (if it exists). I have a 70 280SEL inline 6 with a 55amp alternator but need a little more juice to power an updated autio/video, amp system. (I think 80 - 120 amp would work just fine). Does anybody konw of any bolt-on GM/Delco sort of conversion?
Or maybe a good rebuilder that can up-grade my old Bosch unit.
Any help would be great.
Michael
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
Measure the length of the mounting, where the bolt goes through on the engine bracket, and its offset, the pulley size and offset, and visit the junkyard. You could also make a template out of cardstock to make the comparison.
Check out all the BOSCH alternators in your amperage range and buy one. You'll probably need new brushes or a new internal regulator.
Since you'll be adding sensative electronics to your car it would be best to use an electronic regulator not the older style mechanical regulator.
