1 - 9 of 9 Posts
87 300D Turbo Sedan, 227k when the odometer broke.
I need to remove my alternator but I can not figure out how to release the tension on the belt. How do I do that?
Do a search for a full description with pics. Yours is a OM603, but the procedure is similar other than the tensioner which requires unbolting the spring and shock on the diesel version.
Here's a link that might help (M103 version, but 80% similar to yours)
PeachPartsWiki: 190E 2.6 Belt Replacement
I didn't really see anything searching. Are there any you can find 603 specific?
No, I do not have the service manual.
It looks like I wasn't that far off, I had removed the bolt for that spring, it seemed to take some tension off the belt but it didn't really get all that loose, do I just need to push the pulley by hand and sort of force the belt off? I don't plan to change the belt as it looks fine, just need to get the alternator out and back in.
W124
Not sure if the diesels work this way but on the gas motors I never release the tensioner. I just remove the upper bolt for the alternator and slip the belt off the pulley. Once the new alternator is in place it just takes a little leverage with a large screwdriver once the belt is back on to position the alternator so you can insert the bolt again. 10 minutes in and out tops - but that is on a gas motor M103.
It IS the same on the diesels, with the exception of needing to remove the shock & spring. Actually, the shock doesn't even need to be removed but will have to manipulated by hand to release the tensioner pulley.
I find it easier to just yank the shock, it's only 2 bolts.
This link shows how to do it when R&R'ing the fan clutch.
PeachPartsWiki: R&R of the Viscous Fan Clutch
W124
If you have to release the tensioner then its not the same as an M103 I guess. There is no need to release the tensioner itself, just the belt tension. That can be done by removing the upper alternator bolt and allowing the belt tensioner to relax.
1 - 9 of 9 Posts
