1 - 12 of 12 Posts
1996 S500 and 2002 S600
Please help! None of my power windows are working at all. Is there a module for this? I have already checked all the fuses and the seem ok. Thanks
Jaguar STR-sold,mercedes s500L-sold,c36 amg-sold,s500 coupe-sold,cl420-sold,s320-sold,s280-sold
Convenience modul located in the boot,behind right panel.
Had the same problem
Many thanks; does it have a part number and/or what does it look like?
Yes it's writen across the middle, I cannot recall it what.
Bought a second hand was cheap.
Black box cannot miss it.
.I d three black boxes in this area of y older car (500SEL), one has bose writtenhe adio system; another one looks similar in size with one connection and the third one is a lot b ith multiple connections
Sorry that last reply was a bit garbled! I have found three black boxes in this area of my old 1992 500SEL - one has bose on it so I assume this is for the sound system, another is similar in size with only one connection and the third one is a lot bigger with multiple connections. Which one does it sound like to you?
1993 300SEL (Sold) 2007 X5
This should be it here:
That's from a 300SE but it should be in the same place I think.
Yep the one marked n57
Thanks guys!!! I have just replaced it and now all the windows work great. Can anyone tell me the correct proceedure to reset them for auto up and down i.e. with one touch of the button?
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Reset the Window by just keeping the Button press't for more than 1 second when you either Raise'd or lower'd them and they should be reset ,do that for all 4 Windows .Make sure that you feel the slight Click when you press the Window Buttons ,just press a bit harder than you usually do and you will feel it .
Ciao :thumbsup:
And another thing ,When you done ,leave the Sunroof and some Windows open then get out of the Car and press the Close Button on your Remote Key & HOLD the Button ,all Windows & Sunroof should close ,if you press it again they should reopen and stop in the exact Position you left them prior to close them but that only works for a certain amount of time .
Discussion Starter #11
perfect; all is now working as it should! Thanks guys!
1 - 12 of 12 Posts
