Sounds like a click baity Youtube video title doesn't it
I did my a health report on my A160 Auto, and these are the codes it's returned. I've been researching what they are (and there seems to be some common issues) and have a plan for some of it.
Any pointers/comments/warnings welcome
ECM - Engine Control Module(ME)
P0340-001 No Cylinder 1 Recognition Of Component B6/1(Camshaft Hall Sensor).
Stored
P0340-002 Cylinder 1 Recognition Of Component B6/1(Camshaft Hall Sensor) Is Implausible.
Current
I'll be removing the camshaft sensor and trying to test it. Assuming it's simply broken, I'll replace.
P0135-002 O2 Sensor Heater Of Component G3/2(O2 Sensor Upstream Of KAT): Possible Cause: Open Circuit Or Short Circuit To Ground
Stored
Replace the oxygen sensor
P0725-002 Engine Speed signal(TNA): Possible Cause: Open Circuit Or Short Circuit To Ground
Stored
Is this the crankshaft sensor?
P0410-002 Y32(Air Pump Switchover Valve), K17(Secondary Air Injection Relay): Possible Cause: Open Circuit Or Short Circuit To Ground
Stored
Not sure yet.
P0443-002 Y58/1(Purge Control Valve): Possible Cause: Open Circuit Or Short Circuit To Ground
Stored
Not sure yet.
GRM - Gear Recognition Module
P1856-000 Process Recognition Module
Current and stored
FTC - Front Transmission Control
P1872 CAN Fault : The CAN Signal From Control Module GRM Is Faulty.
Current and stored
I believe these two are related to the PCB board in the gear shifter, and am in contact with a local electronics company about getting that board serviced (resolve dry joint(s) and inspect generally).
Stored
Current
Stored
Stored
Stored
Not sure yet.
Stored
Not sure yet.
Current and stored
Current and stored
