1 - 1 of 1 Posts
In looking at the following document for alignment specs:
http://www.w124performance.com/docs/mb/W124/124_alignment.pdf
I noticed a column for "A. Vehicle Level". Values for the cars ranged from -5mm for Sportline models up to +42mm for increased ground clearance cars. So where is this measured from and to what. I was thinking that maybe this is fender clearance, but I thought the sportline still maintains a gap.
Next question is related to the next chart for "B. Control point of Level Control" This is specific to the rear axle, so someone help me understand this one.
For section "D. Rear axel wheel alignment" why is there not a sportline setting?
Lastly, which of the Sortline specs do I use for wagon on H&Rs? Thanks for any and all advice you can contribute.
1 - 1 of 1 Posts
