2003 S430
My battery was low/dead so I hooked up my motorcycle battery tender to get some charge in the battery...in about 5 seconds the alarm started going off and I ignored it and then it stopped.
Now...the charger is not showing the battery taking a charge and the key will not turn in the ignition.
Did I engage some disable the car feature?
Thanks for the help!!
Zotye Auto 1.5T T600 2016
You give little history here, how old is the battery?
2003 S430
OLD.... :)
I was thinking about just heading up to AutoZone and buying a battery, but at $180...thought I'd see if I just screwed something up electonically by letting the alarm go off.
Thanks!!
OLD.... :)
Thanks!!
With a completely dead battery situation, adding charge often sets the alarm off, just change the battery and see how it goes. There will be a lot of 'low voltage' codes set on all the computers now and you will need to use diagnostic equipment to clear these codes once the battery has been changed or other faults will plague your car.
2003 S430
replaced battery...all things are good now...EXCEPT...I have a warning that says Pre-Safe Mode not activated.
How do I reset that one!! LOL
Just drive the car as you normally do for a few days and the pre safe warning will go away. Remember to reset the windows and sunroof.
2004 S430
I believe that you can also reset the pre safe feature but turning the steering wheel all the way right till it locks and then all the way left till it locks with the car running but in park. It could also be left first then right but you get the idea.
