91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
So the factory alarm went off on Dieter,unlocked the Drivers door,started the car,alarm still on! wtf!so opened the hood and disconnected the speaker lead,whats the proper way of shutting that thing off,my poor ears!
Unlocking the doors should normally turn off the alarm IF the sensors in the doors are functional and the factory alarm module is working OK.
You may want to try by bypassing the factory alarm as shown below
PeachPartsWiki: Disabling the Alarm
97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
On my former 92 300E, I turn of the alarm by turning the ignition on. There must be some short or faulty sensor somewhere in the alarm system. Try to fix it instead of disabling, IMO it's a good system.
86 300e Anke
Anke sometimes 'ignores' the door switch that says 'the door is unlocked... shut up!'. :p
Usually when there's lots of people around...
I just 'unlock' the door again to shut it up.
If it wont work try the other door and/or trunk...
Works for me! :thumbsup:
I have self-locking problem on my new purchased W210. It sucks when the car lock itself with the key in the ignition, even when the engine is off, but good for me that was at selling dealer shop and they had tools and knowledge to deal with it.
So the thread in W210 section come to the conclusion that the culprit most likely is the trunk lock activating central locking and alarm.
Sounds like that is very likely case here as well. I am still working on figuring out my (my son) problem, so good luck on yours.
I just disconnected the alarm speaker,other things to deal with on Dieter the red headed step child! its amazing the difference between my sons 92 with 121K and mine with 230K Deiters just old and beat like me!HaHa!
86 300e Anke
I only have the horns... :(
Tho somebody once put AIR HORNS on her... hope it was just for 'regular' use! :eek:
:D
