2004 SL500, 2007 R350
I wonder can you upgrade the Command System &
screen to update them to the new HD Command Screen ?
Queried that when I picked up the R-class and the screen is much brighter and clearer than my SL but was told it couldn't be done. I'd imagine it must be possible but at what cost?
The hard drive navigation system and storage for mp3's sounds excellent. And also upgrading to Harmon-Kardon instead of Bose!
ML350
It can be done without question.. I already have the cabling and everything worked out. Cost... well thats another matter :eek:
SL550
More than just the head rest
The switch for the airscarf is integrated with the heat seat switch which is different from the pre-2009 MY. To have a completely factory look you would probably need a new switch cluster, door panel and wiring harness.
Now that there is Airscarf in the 2009 SL, I wonder if someone will be doing a
modification kit for the previous models since it looks like you only have to
change the headrest.
