21 - 30 of 30 Posts
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
^^ That has not been my experience. My S600 TT with coil-overs rides and handles very well, indeed. :)
That said, I agree with you 100% about SDS. That's really the only way to properly diagnose this. As for AlphaZT's screenshots, I'm getting "404 Not Found" errors. But from what Deplore says, there's some seriously non-standard wiring, which is probably the problem.
S320 1999 Long
Discussion Starter #22
This is a tipically problems to S-class.
I will change the airmatic suspension with normal suspension kit. I don't like this problems, is verry complicated and i don't find any service mechanic who know to solve the problems .
I verify the compressor, is fine, the electronic components is fine, the airmatic reservor is fine, i open this Screenshot to view if is comming air when the compressor is working, and not, is not comming air.
I don't now what can i do.
P.S : i verify today more about that Screenshot and i find from what is.
Is from this Screenshot and receive energy from the lights, so don't have releated with airmatic suspension functions .
S320 1999 Long
Discussion Starter #23
Can anyone to told me opinions about my problem ? I don't now what can i do next .
I verify the compressor it's ok, i verify the airmatic reservor, it's ok, i verify the valve pressure if is entering air from compresor and yes, and is go from the valve pressure for the spring strut and the car is not up .
I open the spring strut hose and is not comming the air .
So, what can i do next ? I don't have any leaks, i don't now what can i do. Is a verry strange situation, i verify all mechanical principal components and all it's ok and working.
You do have a leak. If you removed the air line from the valve block and air is coming out, but when you remove the air line at the strut and nothing is coming out, then the line is broken.
2003 S500
The system releases compressed air to each of the four struts under computer control. If the computer thinks that the car is at the correct ride height (as measured by the ride-height sensors - one on each front upper control arm, and one on the rear suspension between the center of the anti-sway bar and the chassis), it does not release any air from the valve block to the struts. The computer does hold air in the struts until the computer thinks that the car is above the desired ride height. An example of this is the release of air when passengers get out of the car.
That means that if the car is at or very near the desired ride height, there is no air moving in the system. Air is released from the valve block to the struts only when the car is below the desired ride height.
The movement of air thru the valve block is controlled by electrically operated solenoid valves - if I remember correctly, one for each strut, one for the reservoir, and one to dump air from the struts back thru the compressor inlet hose and filter.
Spend some time reading here:
You probably have a leak somewhere.There is a video by MercedesSource.com dealing with this problem. It will cost you $15 to download but have watched it I think it's worthwhile.It illustrates everything very well. I have nothing to do with MercedesSource.
W220 Moderator
Also many many posts and threads on here, as well as excellent write ups in our Encyclopaedia.
S320 1999 Long
Discussion Starter #29
Ok, i read the encyclopedia and i don't find nothing .
So, if the car computer know the car is up but is not, how to reset ?
You need SDS to do proper troubleshooting of your AIRmatic issues. If you don't have one, then I suggest that you invest in one. It has helped me solve several AIRmatic issues over the last almost-four years, as well as many, many other things. Yes, you are looking at US $600 for a complete setup, and it's the best $600 I've spent as a Mercedes-Benz owner. Without SDS, you're just shooting in the dark.
21 - 30 of 30 Posts
