i have just got an s430 99
the pump seems noisey
when i turn the car off the pump lets out air
and when ya push the rise botton if goes on the sports 2 then says its rising but takes a long time on that screen !
also just fitted 20" wheels they are fine at times even on the lowest setting and then some times they scrub mmmm?
Discussion Starter · #2 ·
can any one throw any light on this?
to nite my car wouldnt rise at all and wi people in the car was far to low and at one point it said to stop!
could it be the pump? the car hass done 74000 wi full histroy am going to check for leaks 2moro
W221 & Audio Moderator
2013 S550
A little searching using terms in your question would have gotten you the answers quickly:
1) You likely have a leak in the upper seals of your front struts.
2) Your Airmatic pump may have burned out because of trying to keep the struts inflated when they had a serious leak, and likely needs replacement.
3) You should probably replace the Airmatic relay as well, as a precaution.
4) The car needs to be diagnosed and repaired by a qualified MB tech - either at the dealer or a good independent MB shop.
1994 Mercedes s500, 2003 Mercedes Benz S500
Airmatic Warning! Visit Workshop!
Could anybody reveal the location of the airmatic pump relay switch? Also what serial number to look for on the switch? My problem: The Airmatic warning light comes on after driving about 5-6 miles. When I press the airmatic button on the upper dash, I get "Car rising/Airmatic warning in successions. I bought the "HELLA" switch and swapped it out, (I know where that one goes), but I did not get any reaction when I pressed the button. I do not hear the pump like I used to and when I stop, and park, turn the car off I 'used" to hear a "Sw-o-oosh" then the car went silent. This has not happened in about 3 weeks, the car is not out of alignment height-wise, but I'm afraid one day, I will suffer the same fate that I have been reading about. I will take the car in on Monday, but, I really want to know what has happened before my visit....ANY help would be pricewless.
Zotye Auto 1.5T T600 2016
Skylaw has just answered all your questions except the relay and its location is left rear of the engine compartment in the relay/fuse box. In your tool kit (in the boot) you should find a relay/fuse diagram.
The bottomline is you have to take it to a dealer/specialist because they are the only ones with DAS and the special tool to do the strut mod.
Thanks, Eric:
And if anything different, I will post it. We need to "bone-up" on anything we can find out and share it,
Thanks again.
