hi again 2nd to my earlyer post
ive found my leak its located on my left hand side rear strut top!
so my question is........
were is the said realy ?
can i buy a kit to fix this strut top?
and can i change the pump my self?
i dont have a warning msg on the screen not pluged it in yet
can is far to low to drive now.
many thanks for ya help
W221 & Audio Moderator
2013 S550
You may have any or all of the problems I mentioned in response to your first post on Airmatic problems. Others have written up information on DIY changes, including the need for a special tool, its cost and where to get it, the part numbers and cost of the upper seals, the location and cost of the Airmatic relay, and replacement of the Airmatic pump. Also, if one front strut seal has a leak, the other won't be far behind; and you may (or may not) need adjustment of the ride height sensors using STAR diagnostics after the parts are replaced. That's why I suggested you use the search tool a bit in response to your first post.
If you don't want to have the car towed and seen by a qualified technician as I suggested, then I again suggest you use the search tool on this forum, and on MBWorld. I don't have all of it bookmarked. When you do your search, don't forget the "similar threads" portion that appears at the bottom of the page.
mb want
1500 GBP + VAT @ 17.7%
i only give 8000 for the car plus i like to get involed wi the diy side of my cars
i changed the auto box on my w140 even tho most said get a mb specialist to do it,
am goning to stick on computer to day and see wot codes i get back then
poss change the strut for a junk yard one and then new pump and rely
2001 S430
How did you come up with the leak on the upper rear strut? What exact location? Give a little more info where your Avatar goes so we can know where your from,model and year of car.
mb want
When did the British start issuing a Driver's License and allow a Baboon to register and plate a W220?
