just done my head gasket on my m104 engine...e320-24v......pics to follow soon.............
does anyone know how to get rid off the airlock?
thanx
thanx
If you are referring to "no-heat", then you should bleed the system at the drain plug in the block. I had an airlock when I pulled the heater core to do the evaporator and it took about 250-300 miles of driving to get the system burped. I did not try to bleed at the block, but this is the only other way.
