1999 SL 500 Sport Pk
I have a 99 SL 500 and the Airbag off indicator located on the dash keeps coming on...I have turned the key lock above it to ever position but it always comes back on...This light does this regardless of the weight of the passenger and I can't figure out how to cut the Airbag on....The SRS light cuts on and stays on as well? Any thoughts
ML430/ SL500 SA
Isn't that lock for the little glove box?
Look on the side of your passenger seat with the door open and see if the switch is moved to display the little white child figure.
That was the fix...Thanks a lot for your help!
