Hi Guys
Well in short I've been trying to set WUR pressures for the last 3 weeks ( I have a seperate thread on that ), I've got close but the engine still seemed to be a uneven. Tried mixing the CO2 mixture and it helped a little, but engine still uneven. So as advised on my other wur post I've invested in a smoke testing machine.
The outcome of the smoke test was a small air leak coming from 1 injector from each side of the block, 1 leak from the idle/tick over screw and 1 coming from the pipe going into the fuel distributor housing...
My question is would these leaks affect the actual wur setting calibration and co2 adjustment, and cause the engine to still idle a little ruffly..
Will try to add a short video
Cheers
Cheers
