I replaced my fuel filter on my '86 230GE (as directed by an article on the clubgwagen.com website.) The fuel filter installation went great. I was then referred to another step (in the Fuel pump replacement article on the same website) and was told that you needed to remove the air out of the fuel line. The problem was that when I went to perform this step, I believe I located the fuel return line, but I could not locate the fuel pump cutoff safety switch.
I have included a few pictures to hopefully aid your suggestions in locating both the 'fuel return line' and the 'fuel pump cutoff safety switch'.
Thanks alot
Thanks alot
