73 280SE 4.5, 71 300SEL, 03 BMW Z4, 72 Fiat 850, 80 Triumph TR7, 85 Porsche 911
So on the ECU is the air/fuel mixture control. After replacing a lot of vacuum lines, my car runs differently (which is to say, more rich now). The exhaust smells more like gasoline than anything else. I suspect I'm on the road to solving other, lingering issues as a result (yay me).
Anyone remember which way to turn the knob to lean out the mixture?
64' 220SEc, 72' 300SEL 6.3, lots of parts
GrubeG,
Set MCU box in the middle of the clicks.
Then adjust the idle air screw,
If it increases idle speed then it is too rich,
If it doesn't then idle fuel is set.
Then I have leaned the MAP sensor (no more than 1/8 a turn at a time) so that the idle does not increase and achieves a solid low idle speed.
Then the MC|U will respond rich and lean with a few clicks.
This EFI really simulates the older MFI
At least that's the way I observed the response.
when the air screw is turned in, the mixture gets rich because the air is reduced the fuel stays constant.
Of course the timing is set perfect?
Vacuum diaphragm on distributor is good?
