I have an 81' 300 SD turbo diesel and am having problems with the air filter housing. The housing vibrates too much and in return it breaks the brackets that it is mounted on. Is there any way to install a newer model air filter housing which will mount on the body, not the engine. Thx
Discussion Starter #2
I've had a few 300SD and all vibrate. If the bushing is new, it should keep it from vibrating too much and also shouldn't break.<p>excessive egine vibration is also caused by worn engin shocks. not really expensive and they're simple to change.
