I recently had my air condtioning converted. There was no sucessful cold air flow, due to the blend door being stuck. can any body help me with this find, fix, and solve this hot air delema? any tips tricks or shortcuts would be great.
84 230CE & 84 300DT
Check your vacuum lines that go to the blend door actuators and the actuators themselves.
How would i attempt to check the actuator and the vac. lines?...
84 230CE & 84 300DT
The best thing for you to do since I don't expect you to have a hand operated vacuum teste...
The best thing for you to do since I don't expect you to have a hand operated vacuum tester is to run a piece of spare vaccum line to the actuator (aka vacuum motor) and apply some of your own vaccum by mouth. If the actuator works then your problem is that you are not getting vacuum to your system.
