serp belt
so, I think I had a similar problem that, touch wood, is now fixed. my a/c seemed to cut out when idling and my temp appeared to go up a little higher than I thought it safely should. Took it in and they fixed the following: Dual temp switch, wire connection from aux fan to receiver drier, serpentine belt & belt tensioner shock. Not saying your has all of the following issues (sounds like we had the same set of symptoms). I'd start with the belt and go from there. hope this helps.
