Hello,
Recently purchased a 1998 C280 at about 90K miles that has an air conditioner issue. The compressor doesn't run and the EConomy light stays on. I have read that this can be caused by a faulty sensor and that it can be diagnosed based on the readings obtained from the climate control panel.
I have retrieved the readings but don't know what they should be. If anyone could take a look at the readings and let me know your interpretation, I would appreciate it.
1 68
2 61
3 75
5 127
6 111
7 2.5
8 64
9 50
10 495
20 0
Outside temp: 62
Engine running for several minutes but still cold.
97 C200 Kompressor Elegance
I have the same problem with my 97 C200 Komp, and am looking for the fix, too. I had read somewhere that if you press-and-hold the EC button for 10 seconds, it would go out. Sure enough, it works -- and the AC compressor kicks on, runs cold just fine. It's a workaround, but will get you AC. I'm hoping someone replies with what causes the problem - and how to fix.
Texan2, I will try that tonight.
300B, thanks for the reply and direction. Can you tell me which parameter indicates this and what it means along with a good place to pick up the aforementioned part?
Once again, thanks for the help.
