I had for some time this message, today morning it appeared just after starting the car (usually it was during driving), picture at the bottom.
Now the car doesn't lift up, after a check with star it says that the time to obtain the pressure value is too long and/or that there's a leak.
I ran a compressor test and the pressure was still in the red after 40s. (~13bar).
It seems that the compressor is less noisy than before
, thought it was dead before noticing the pressure value raising till 13 bars. But the car doesn't lift up with 13 bars either, is there a secure mode if pressure stays in red ?
If it helps pinpointing, both front struts are very deep (-70mm), the rear is nearly OK with is range.
Thanks for your help, it's the first problem with the air compressor system and my first use of DAS. :nerd
