Inaccurate information given to you
I'm afraid they gave you inaccurate information.
There is a kit for voice control. It works on E series vehicles with M.O.S.T. I'm pretty sure it will work on the S series also. The part number for the kit is:
BQ 682 0928
It contains the following parts:
Lever, PTT A 000 545 11 44
Cable, MOST, w/voice A 211 540 66 33
Control module, voice BQ 682 0929
Manual, voice control P-2799-04A
:thumbsup:
W221 & Audio Moderator
Your dealer is an idiot. See http://phdwebsite.powerpulse.cc/Phone Install Bulletins/2005 SL.pdf
The Voice Control and telephone system are most often installed at the Port of Entry, after the car is shipped from Germany and after arrival at its destination.. It can certainly be installed by a competent dealer - and that may be your problem.
The vacuum is the part that pulls the trunk closed the rest of the way. It is the "assist" part as you called it earlier. It is called a rear trunk lock vacuum element - part #230-750-01-85.
