ML430, 2000, Silver
I saw some quesions and answers. but I can't sure I need to program or not.
After installing aftermarket HID, Do I need to go to Dealer and program it?
ML430, 2000 ( I recently changed new projecter type lights)
ML430, 2000, Silver
Discussion Starter #2
If I have one installation kit of HID, is it working for only low beam?
How do I ..high and low beam work together?
Except buying new bi-xenon headlight.
1999 ML 320
well my friend has aftermarket on his ML...don't think he had it programmed at the dealer [also projector housing]
i have also read the threads you are talking about...and well from the kits ive seen...it should just plug into the socket for your normal halogen bulb [connecting to ballasts etc..etc..]
also on the projector...you have a separate chamber for high / low beam...so you would need to get a separate HID set for the low....don't think its really that necessary...but to each their own i guess.
hope it helps.
98ML320
Year 2000 doesn't require any programming, just proper aiming.
If you go buy a second set of xenons for the hi-beams wouldn't it just be cheaper (and easier) to buy the bi-xenons to begin with. Plus, the startup time for seperate highbeam xenons would be a few seconds (not really practical).
Basically by going aftermarket the way you have, you've created older style low-beam-only HID lights.
