1 - 8 of 8 Posts
1983 230 E (sold) , 1991 600 SEL (sold) , 1993 300 SE (sold)
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
2003 S55 AMG Kompressor
Recent tests in German magazines have consistently shown that no-name brands perform better then Bosch and Varta for a portion of the price.
I've been using generic low-cost (european) brands in a couple of our cards. The last one I bought was a Bosch, but that's just an co-incidence
They all probably come from the same OEM I suspect
Thank you for your replies, im leaning towards merc s500 advice. The specifications that I have chosen is below with all the details
Varta
Start Stop Plus Starter Battery
Voltage: 12 mm
Battery Capacity: 95 mm
Cold-test Current, EN: 850 mm
Terminal Placement: 0 mm
Hold-down: B13 mm
Length: 353 mm
Width: 175 mm
Height: 190 mm
I think it is compatible and adequate power or the 600. If you guys could confirm this, it would be much appreciated. The price of the baterry in Serbia is arround 150 Eur.
1 - 8 of 8 Posts
