Sounds good.I've never tried that, but @Deplore may be able to help![]()
Hummm, did not know they were not virginizable. So the whole using a used EIS is a lost cause on these old cars?Not a good idea to virginize eis that have two processors, it almost always fails.
Only way to do it is to use vvdi prog or other equipment and to do a full flash + eeprom copy.
210/220 eis and their variants (202/208/215) are not virginable... Not easily anyway. I don't bother.
Why are you virgining eis? The only time you would need to do it is to a EIS lost case, or to program a ESL emulator (though that isnt required anymore).
Hummm, this has no ESL. Trans is 722.6. No locked steering wheel, no locked shifter. EIS is still readable with information still stored in it while in car. Car is a 2001 S430.EIS is the master immobilizer for the whole vehicle theft system. All other immo parts are slaved to it.
So if you are replacing an EIS for whatever reason, you always clone it over. Some EIS are not cloneable. 210/208/202 are not cloneable due to the difficulties and the fact that the MCU dies when you heat it up with a hot air station to remove it.
And if you do have to replace an EIS because of whatever reason and the original one is not available, you have to virgin all immo in the car, and then do the drive authorization with Xentry. When I say all, I mean ALL. ECU, 722.9, cluster, ISM/ESM, ASSYST, etc.
I went through this last week, actually. 204 chassis came from auction, no EIS because locksmith came, took it to make a key, and then locksmith disappeared. Got used EIS with key, virgined ESL, cluster, ECU, 722.9 and then did the DAS for all. Car started afterwards.
You have to switch back to OBD and then write the VIN afterwards.I thought it did that, but i did not see it personalized after. It came up with checks missing in Personalize and activated. And all keys disabled.
Nope, not I, but the dealer did way back when and have seem to forgotten about fixing it.
Nah, only the early ones. Later ones can be used with little trouble....unless the EIS is FSB4. Right now there is no known way to read a FSB4 EIS when all keys are lost. FSB4 refers to the immo generation -- similar to the key generation with 1 being the old motorola big key and gen 4 being the latest chrome key with square buttons.It sounds to me like MB have designed that newer chip to stop guys unsoldering them and using programmers![]()
I did switch back to ODB.You have to switch back to OBD and then write the VIN afterwards.
Now that sounds like very good info.That doesn't sound right to me.
Here's the step I'm familiar with, maybe its different....
-read original EIS, read key pass, generate erase password, save the .bin file
-read donor EIS, read key pass, generate erase pass, save .bin file
-renew donor EIS with IR
-Write the original EIS .bin file to donor EIS with IR
-Write VIN through OBD
At this point it should activate and be personalized....?????
I forgot, I'd have to redo it sometimes this week to see whats the actual procedure, because like I said....I don't renew 220 EIS at all. Dual processors and all that jazz.
Of course not! Where is the fun in that.Then in that case you'd want to use the VVDI prog to restore the flash + eeprom.
....you did make a full backup, right? ?
Which seems to hold true as I was able to figure out where most of everything was. I noticed that what I needed to change never changed. So that means programmer to me.eeprom content is usually the VIN, mileage, key pass, key hash and key 1-8 hash plus the rolling codes, plus the remote hash keys.
I don't do much .bin file editing, I just don't have the patience to sit there and figure out which address range corresponds to what. What I do is to verify the .bin files against multiple reads and multiple verify's so I can be sure that I have a good read and not a corrupted one that constantly changes between each read.
Reason why everyone is willing to look at it is because they aren't reading the eeprom .bin file by itself, they almost always have a program that they can feed the bin file and it'll translate the contents into nice, easy to understand language.....like english! VVDI is one such program that can decrypt bin. SKC is another, usually comes with AK500. Or CGDI. Or or or or....whatever. There are many different ones.
Oh, forgot to answer....no, the EIS doesn't have checksum verification....yet. I think FSB4 does have checksum verification, which may be one of the reasons why no one has cracked it yet. The newer ECU does have checksum, but only on the mapping data.
