Went on 2hr drive after about 30 minutes the volume kept getting louder and had to be turned down several times to keep a resonable volume. However, at a stop the volume would be so low that it could hardly be heard. The volume would go back up at 1500 rpm ingear or in neutral. Both CD and radio performed the same.
2002 C230k
This is a mistery to me. Ordinarly, I would suggest the things you have already done, setting the speed sensitive volume contro to 0 which is off and disconnecting the mic for the Bose system.
I wish you luck in finding the source of the problem.
