1 - 13 of 13 Posts
1993 300e 2.8
My daughter has started driving my 1993 300e. She wants to hook up her phone to the radio for music. Anyone know how to do this?
Thanks in advance,
Rick
1990 Benz 300E 2.6 (mine) ; 1994 E320 Wagon (wife's) ; 1993 300CE Cabrio, needs some TLC
method 1) take the factory radio, and send it plus $$$ to Becker, and they will install an aux cord or blue tooth adapter or something.
method 2) get a $100 Pioneer/etc stereo with aux jack and bluetooth, and the appropriate harness adapter, and wire it up and plug it in.
method 3) if your cassette still works, get one of those stereo cassette adapters and plug the wire into the headphone jack on the phone.
each method has pros and cons.
04 E320 4M Wagon, 90 560SEC, 14 VW Sportwagen TDI
I added a AUX in cable directly into my factory Becker, Not a complicated process but you would need to be ok using a soldering iron to connect a couple of points. Ultimately you are just tricking the system into thinking its playing a tape.
Becker charges $130 i believe to basically trick the system like i did.
If you want to do it yourself let me know and il send you the steps
2011 E550 4Matic, 1992 500E, 1994 S124, 1994 E320
The Becker Aux requires a cassette in the player to activate the aux port. You can do just as well with a cassette adapter for about $5.
Cassette Adapter
don't those Beckers have support for an external CD changer? I'd think /that/ would be the place to insert the aux in, since CD out is the same signal level etc.
For MY92 and up i think so, Uses a 6 pin BUS or something like that, Pretty sure it can be done using CD changer controls. 1988-1991 BE1480 has no CD changer option
ah. all three of my 124's came to me with either no stereo or aftermarket, so thats all I've dealt with. still need to upgrade the wife's wagon's deck, its an older in-dash CD player that doesn't have any sort of aux in provisions.
93 190E 2.6; 82 300 SD Turbo
I've been successful in modifying a few 1480s to have AUX input without any tape requirements. Also did some of the earlier 1970s radios too.
The aux input could be replaced with a bluetooth module or a combination bluetooth+aux module.
1991 Mercedes Benz 300E, 179K, stock, daily driver
no distortion... hahahaha. as soon as you put it on FM, you're dealing with significant compression, loss of high and low end frequency response, and limited stereo seperation.
https://www.youtube.com/watch?v=mj53FiYB9UY
Any DIY instructions for this? Really would like to attempt this on my 1480.
[QUOTE = "LTYLER, publicación: 15058329, miembro: 31840"]
Agregué un AUX en el cable directamente a mi Becker de fábrica. No es un proceso complicado, pero necesitaría estar bien usando un soldador para conectar un par de puntos. En última instancia, solo está engañando al sistema para que piense que está reproduciendo una cinta.
Becker cobra $ 130, creo que básicamente engaña al sistema como lo hice.
Si quieres hacerlo tú mismo, házmelo saber y te enviaré los pasos.
[/CITAR]
1 - 13 of 13 Posts
