I have been driving my E350 Blutech for 2 years now, it has been an amazing trouble free car up till now. I have had an engine warning on for about a month codes P106100 and P108800. Last week I decided to add DEF, put in 2.5 gallons. I then got an error countdown 16 starts remaining. I then went to the dealer and got enough DEF to totally top off my tank. The counter is still counting down. I called the dealer he said the car needs to be brought in and NOX sensors changed [$700 eash] plus reprogramming. Overall about $1800. OUCH. I have been searching for the answer to reset the countdown and haven’t had any luck. I did find on the web a blue cube that is put into the OBDII socket that is suppose to clear the fault. Is there anyone that has tried this OBDII cube? Should I change out the nox sensors. If so how do I reset the countdown code.
Hope there is an answer out there. The car starts and runs great but I only have 6 starts left, and from what I have read after that it will have to be towed to the dealer to be fixed. Any help would be appreciated. Until then my car is parked:frown
Jim
Jim
