2011 E350 Bluetec
Check engine light on. Dealer says Ad Blue Level Sensor needs to be replaced. $2000+.
So questions are, is the level sensor separate from the heater and heater sensor?
If it is just the level sensor, do I even need to worry about it? or will I get the countdown eventually?
I will say that the entire DEF system that MB uses is complete horse crap.
Likely it will come to cont-down.
It is crap to make no replaceable parts on $2k + tank, but similar it is with $1300 4M front axle where failed CV joint can't be bought separately.
The sensor is sonar technology, so not likely aftermarket will go for cheaper options.
2011 E350 Bluetec
Yes... horse crap... I replaced mine as a weekend DIY project. What I learned was there are only 3 main parts for this section of the DEF system. The DEF Heater, the DEF Pump and the DEF Tank. Did MB Dealer replace the heater?
