Adaptive dampening system (ADS)
24K views 17 replies 7 participants last post by  andy380SEC
#1 · (Edited)
I've been scouring the internet looking at probably buying a face lift, I've found a 1999 and got a friend to get me the VIN from the reg number from the ad so I could pull up the datacard.......It has ADS, is this a good thing or a bad?...Something to steer clear off or be happy about?...Obviously it's going to be more complicated and expensive to fix, but are there any known reliability issues with that suspension?...Cheers. I forgot, it says ADS with skyhook...I'm fkd if I know what that means.
#6 ·
By the way thanks for the information earlier, I've been setting up a new PC so just read it.....I had read that before but couldn't remember or find it....As for this ADS sounds good in theory but like you say replacements will be silly money. I think I'll give that one a miss although it looks really nice,maybe I'll do some more research....The other thing going off what you said I might hold out for an '01.
#8 ·
I'm not sure, but doesn't the road tax change on an '01 which makes that more costly?
I have converted self levelling to standard suspension on one of my other cars when the original shocks wore out. All as it takes is the removal of some pipework and replacing with standard shocks and springs. I bet the computer would throw up an error in these cars though if you were to remove the electrical connectors from the ADS shocks.
#10 ·
Shaun,
Thanks for setting me straight on that item. Again, I don't believe it was offered over here.
Which brings me to another point. I'm somewhat envious at the different options (from MB,AUDI, and others) that are available in the EU than in the US on the W210. A couple that come to mind would be the folding ext. mirrors, heated rear seats, rear reading lamps, skid plate, etc.
I have a MB vehicle option code book that even lists a floor safe available in our cars.
Cheers !!
Mike K.
#13 ·
I'm still trying to find more info on it.....On the datacard it says adaptive dampening system (ADS) with skyhook.......Option 214....It doesn't mention front or rear, but as you can see on my other post 214 says rear and 216 says all round. Does yours have a button on the console for changing settings or does it just just control it's self......If you PM me your VIN and e-mail address I can look up you data card and see which options it has and send it to you, that's if you don't mind? Cheers. Shaun.
#16 ·
I ended up buying a 2001 facelift with ADS, the button as B15 MAT says is above the front window switch. The rear is supplied with oil from the pump which also is the power steering pump and one reservoir for both. The front shocks have an electric solenoid, the switch only has on and off settings.....I found this article that explains it quite well. V12 Uber Alles, Diagnosing the Adaptive Damping System (ADS) in a Mercedes Benz S600 . Although it may be modernised a bit since.I read about the "skyhook" somewhere but can't find it.
#17 ·
My ADS switch was lighting up when pressed but to be honest I couldn't tell any difference between on and off.
Today while using my friends computer system to activate the phone, I noticed in options it said "off" next to ADS.
I did a few clicks and turned it on, only driven round the corner so I haven't noticed anything but why would it be turned off at a software level?
Only thing I can think of is that with it being an option is that it was never turned on from new, it's in a list of other options such as TPMS....Possible mistake at the factory or someone in the past turned it off?
#18 ·
I have a CLS with SPORTMATIC and I honestly can't tell the difference between I,II or comfort. More MB horsecrap to drive up the price. My 97 E50 had that, same thing didnt notice a difference. I think its a gimmick. Either that or it wears over time to the point you can't tell. Sky hook is just saying that its computer controlled Solenoid/valve actuated.
