1 - 1 of 1 Posts
1999 ML430
99ML430 .... Is there any other way to rotate the torque converter so that the drain plug is accessable? Standard procedure is to rotate the flywheel with a 27mm socket until the plug is visible in the access port.
Can this be accomplished by rotating the rear wheels or at the torque converter itself ?
1 - 1 of 1 Posts
