Hi everyone!
My friend has a 1998 c230 4 cylinder. The issue is sometimes the car will have a acceleration problem. He will even floor the pedal to the ground and the car will not increase in rpm's. The car will somewhat sputter and struggle to gain speed. He said the problem will normally only occur after he has pressed the pedal all the way down and pushed the transmission downshift button which is behind the accelerator pedal. But it will function correctly at first, properly downshifting the tranny and accelerating but soon after it acts up.
Do you think its possible that the transmission gets stuck in a higher gear after it downshifts?
Could you give me any tips or sensors or parts that i should test?
Thanks for your help
