Hello again!There should be two sensors on the engine block - one for the temp gauge, ...
Hello again!
Sorry if I wasn't clear earlier - you should disconnect the wire going to the sending unit, then connect the wire to a suitable ground like the engine block or negative terminal of the battery. If you ground the wire that goes to the sensor for the temp gauge, your temp gauge will peg out (and possibly be damaged if you keep the ignition switch on the 'on' position for more than just a sec). The wire you want to ground is the one for the climate control. If I remember correctly, the wire is connected to the sensor that is closest to the front of the engine. Keep a close eye on the temp gauge - if it pegs immediately after turning the ignition switch to the 'on' position...you've got the wrong wire grounded. The wire for the climate control doesn't have anything to do w/ the temp gauge in the dash. Oh...please be careful and try not to ground the glow plugs or 'wires' going to the glow plugs...lots of current going through these...a fire could result of the glow plug wires were grounded and the ignition turned on...
Also - have you checked the fuses? Sometimes these fuses get corroded and the terminals they sit on need to be cleaned. There should be one 'hidden' fuse over by the relay panel on the driver's side of the engine compartment (this is how my uncle's '78 was anyway...). The relay compartment is close to the fuse box, its located on top of the wheel well adjacent to the fender. Its normally covered by a black plastic cover...remove this to reveal the relays (normally two relays here), and a round housing for a glass-type fuse. Check this fuse, its part of the climate control system - its easily forgotten about as well!
I just hope that the info I've given you is relevant to your 1980. If my memory serves me right, the stuff I've told you to look for so far has been stuff that was relevant to my uncle's '78. Hopefully I haven't gotten stuff in there that applies to the other climate control system offered from '81-up. Anyway I'm glad I could be of some help to you - let me know if you need any more info!
Even better, if you have a chat program like MSN, AIM, or ICQ - maybe we can chat there sometime! It will be a little easier to try to figure things out that way!
Anyway good luck with everything...again let me know if you have any other questions.
