I am looking for a part number for the speed sensor located in the AC compressor. I see one listed at several places that looks like mine but the 400e doesn't come up as an application.
It's a 92 400e.I am looking for a part number for the speed sensor located in the AC compressor. I see one listed at several places that looks like mine but the 400e doesn't come up as an application.
1992 USA models with M119 have a manual belt tensioner with rubber bearing, that can wear out. These also have an 8-rib belt & pulleys. Be careful adjusting tension, remember to only adjust with the main bolt loosened, and adjust on the loose side. Excess tension will shorten the lifespan of the rubber bushing. New OE tensioners are very expensive.There was a e420 in the wrecking yard... I noticed a different style of tension-er on this car, will that transplant onto the 400e?
