2007 SL55 AMG P030 -2007 S65 AMG
I replaced the compressor (new), expansion valve and dryer on a 2008 SL550. I used a Robin Air 34778 to recover, vacuum, leak test and charged 2.03lbs of Freon 134A.
I get 60 degrees F out at the center dash but should get 40-45 degrees F.
After the install I get 60PSI on the low side and 150PSI on the high side it should be 30 & 230 so what is issue?
Bad compressor, blockage in high pressure line any comments, hints would be appreciated.
Happy motoring
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
That sounds like a compressor issue to me. Usually when it's the dryer or the expansion valve, the pressure is good, but the evaporator doesn't get a good flow of refrigerant.
Thanks for your reply, yes I'm thinking the same thing so I'll get a replacement under warranty from O'Reilly.
I've had compressors from them before and had no issues. I'll report back when I get done.
Best H
