Hey guys, just have a basic question about the AC system. I have a C240 2002 and when I take my AC off of the auto mode and put it manual its seems like the center air outlets give cold air while the sides give warm air. The temp was displaying 73 on the display screen and I had the dial on both on 72. If any one can please explain this I would realy appreciate it. Also I could never figure out what the blue dial in the middle of the center air outlets was for,it has blue lines on it and not white like the rest. Thank you<p>spider-wm051.proxy.aol.com
Discussion Starter #2
I think I read earlier that you can let in cold air into the car using the center vents. It depends on your the setting of the blue wheel in the center. I would turn that blue wheel so that the blue disappears. that may take care of your problem. Someone else on here that is more educated on this may have a better explanation<br> <br> <p>250.washington-14rh15rt.dc.dial-access.att.net
