1 - 17 of 17 Posts
1993 300se, 07 cobalt, 2006 pontiac solstice, 03 explorer, 1963 impala, 1966 Lincoln Continental.
A few days ago, I noticed oil on the ground and after tracing it i discovered that the high port AC line I believe, it was leaking and after i touched it at the black cap the gas and oil started to scape even more.
Does anyone have the correct part# and how to replace it?
Here is a picture of the fitting I'm talking about.
The first picture shows where the location of the fitting is.
The second picture shows with my key pointing where the oil and gas was scaping from.
Thanks for your help.
1998 S600 LWB 2011 GLK 350 4matic 2013 Sprinter 2500
If refrigerant is leaking at the cap, more likely the problem is the valve core (needle, schrader etc.).
2003 S55 AMG Kompressor
Yes, sounds like Schrader valve. Make sure to put back only has but also oil into the system
:confused: can you guys elavorate alittle more, the black cap was not leaking it was after the cap right in between the silver and the brass looking metal. How can I fix it? or should i take to dealer?
Thanks for the reply BTW.
Here is where is was leaking from all around it.
Yellow arrow is pointing directly at it.
Any body knows where i can get this type of fitting for the AC?
I went to the dealer, but they are trying to tel me that i need a new condenser and they don't carry this fitting.
94 s420 250kmiles
replace the valve inside you should be able to get one at some repair shop that works on a/c systems, then get a high pressure o-ring to replace the only you ruined when you took off the valve, and then reinstall.
I will try replacing the o-ring first. The shop where I took the car to told me that the car had converted from R12 to R134a and the fitting was after market, so I ended up at the dealer. Anyway after looking at the fitting I decided to take a chance and replace the o-ring first.
I've been trying to locate this fitting just incase the whole valve is bad. If I find the o-ring, how tight the valve has to be?
Discussion Starter #11
Discussion Starter #12
I tried a few shops, and they telling me to go to dealer.
94 s420 250kmiles
none of the w140's were ever shipped with r12, try to avoid that shop at all costs lol
if you don't mind getting your hands a little dirty you can make a few stops at a few local junk yards and pull one off another mercedes as long as it looks like the same part.
Discussion Starter #14
I will try the o-ring first, if that fails, on ebay I found a good use condenser with the valve and fans for less than $100. Does the o-ring has to be green? or just any o-ring with the same size will do?
That is incorrect. Early cars were shipped with R12. A 1993 model should be R134a from the factory however
94 s420 250kmiles
last sentence in page 131 of owner's manual for 1991 300SE,400SE,500SEL
"All W140 use R-134a refrigerant and special lubricant (Never R-12)"
1 - 17 of 17 Posts
