1997 E320
Ac works for about 5 minutes compressor shuts off. Put gauge on high pressure side on it goes to the retard side, building up to much pressure where should I start to look for the problem. 1997 E320
1998 E320 base sedan @ 160kmiles
Have you recently charged the system ? what are the low and high side readings when the compressor is running and not running ?
Dallas, Texas
How high? Overcharged? Full of air? Fan clutch pulling air? Condenser fans running?
Reactions: mrboca
1997 E320
Can’t remember the pressures but on high side gauge went to retard on high end condenser fans not running I’ll get pressure readings when I gauges back no current coming to fans. Fans do works i jumped them with leads
E250 Bluetec Sprinter250 Bluetec
How about spending about 90 seconds of your time and doing proper troubleshooting per link in stickies?
If you obtain and post high / low readings when the compressor is running and not running, it will be very helpful. The front fan will start turning when the high side pressure is above about 200 psi. When the compressor stops turning the fan will stop (unless the engine coolant temp is also quite high).
