1 - 14 of 14 Posts
92 500 SEL, 84 GMC Caballero, 82 Suzuki GS1100GLZ
No ac , good pressure on r134.
Compressor spins for about 3 seconds.
Used diagnostic but don't know what it means.
92 500 sel
Any ideas?
Discussion Starter · #9 ·
20 is too high. Should be about 7 bar without the engine running and about 12-14 bar with the a/c on.Sounds like the system may be overcharged.
I tried shedding some pressure, same behaviors.
It acts like a clogged or bad expansion valve/ orifice tube.
Anyone know where it is?:banghead:
1993 S600 coupe (RHD)
i agree with MikeJT, check for slipping clutch plates on compressor. i had exactly the same as you describe and Mikes old thead on this issue helped considerably, thanks again Mike. sprayed some degreaser between the plates and it made a big difference, still not right but on the way there.
W220 S320 CDI 2005; W140 S280 1994 (Sold Nov. 2012)
Are you saying that your pressure with the compressor running is still high?
I don't think 20 bar will cause the controller to stop the compressor running because it's quoted as the pressure to switch the auxiliary fans to max. speed (K6JRF Auto Page).
Mike
Discussion Starter · #14 ·
Messed around with it for 2 days, wouldn't work.
My mother in law gets in it today, ac works flawlessly.
Got to do something nice for the car when I get home
1 - 14 of 14 Posts
