2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Hey forum
Yes I am still with you, I never dreamed I would keep a car this long but........
Any way, I did a flap test and have no ac anywhere (compressor etc ok) and fails at 2 right diverter and defrost and no foots,
So,,, I would like to replace ALL flap motors if I new where they are.
Is there a diagram ( my searches failed) of the flap motor location and functions?
B
Also
Is there a kit that includes all the vacuum actuators that I can buy?
B
1998 E320 base sedan @ 160kmiles
You can buy what you need one actuator at a time from EBay or Amazon or any other seller. But make sure that the actuators are bad, not the vacuum lines or line connectors. Sometimes, if there are problems with the vacuum supply to the switch-over valve (that controls the flaps as in the diagram above) you may have problems like that. Replacing the flaps / actuators is a painful process, as it involves removal of some parts of your dash to reach them.
WOW
there are 8 actuators and a control valve !!
this could get espensive, like you say I will look online.
THanks great diagram
B
