1 - 8 of 8 Posts
2003 E320 / 1999 ML 320 (2)
My AC compressor has been working intermittently.
When it disengages and starts blowing hot air I can pop the hood and move the wire around that connects to the top of the compressor and it comes back on and works for a while until I have to repeat the process maybe next day.
Has anyone had any issues with the connection at the compressor or is this a bigger problem?
Any help or guidance here would be greatly appreciated - it was 90 degrees farenheit in the Northeast yesterday.
Thanks in advance
I did as you instructed 43sqd -
I disconnected the plug from the compressor and thoroughly cleaned (oil and grime) it and the female side with MAF sensor spray. I also hit both sides with compressed air real good. Then I reconnected everything with a small drop of crazy glue to help keep the 2 sides mated.
So far so good.
Thank you Sir!
2000 Mercedes Benz ML320
So far so good.
Thank you Sir!
I hope your A/C clutch will work reliably.
If you have again the problem, then you have an additional element to blame - the Crazy Glue. Thin liquid may be pulled by capillarity forces further than planned, and at curing that may become a solid layer reducing metal contact surface.
mercbentz
...... just a small bead of glue on the EXTERIOR of the connection to keep it in place - truck is ice cold now - with no interruptions.
When electrical connectors become brittle and weak, this strategy has always worked for me - exterior only gents.
It's your car, so you can do whatever works for you.
CA based - Crazy - Glue can interact chemically with certain plastics, and make them brittle.
The connector has a locking mechanism - if broken, you could have used insulation tape, to wrap around. Collapsed contacts can be brought back to original shape with a fine screw driver.
Gel glue can be used to prevent uncontrolled penetration of liquid glue inside or between the contacts.
mercbentz
mercbentz
Dear Sirs,
After revision of my Denso AC compressor I noticed a small leak coming from te electrical connector. At first I thought it was related to te gasket on the connector and started looking for a part number. I ended up reading this thread and noticed the statement from @mercbentz that the connector has a locking mechanism? What kind of locking mechanism? Appreciate anyone that could clarify this for me. Until I thought it just was a pop in connection.
Thanks allot in advance and regards from The Netherlands!
1 - 8 of 8 Posts
