1998 E300TD
Anybody know if this is a big job or not. I have to hit the bottom of my glove box to get the blower motor to kick on. It works fine from then but I guess is going out...Any help would be great.. Is that the motor or regulator...any suggestions where to get replacement????
Thanks Ken
Changing the blower motor and regulator is not a big job, I got a 2nd hand unit both bits from ebay for £25 about 6 months ago and it works perfectly so guess I was very lucky.
If you look under the glove box at passenger footwell you will see a section held on by 2 philips screws, undo them and you will see a plastic covering, its held on by either 5-6 screws- needs a t20 screwdriver to remove them, after that unplug regulator and remove 3 screws holding the whole unit in, simply swap units over, plug it in and screw everything back together, all in its a 10-15 minute job.
Hope this helps .
